Re: Original Lift-all hitch Farmall H
Posted by Dan Kelley on April 18, 2002 at 09:25:22 from (216.229.35.84):
In Reply to: Original Lift-all hitch Farmall H posted by Hal Davis on April 17, 2002 at 10:08:46:
I was told that I could use the lift-all pump with an aftermarket 3-point hitch, if I make sure the cylinder size is correct. No one ever told me what size cylinder to use.
Also, I believe the lift-all pump only lifts. I may be wrong, but I think the implement weight provided the downforce. This is something to consider if you plan on drilling post-holes or something where downforce might be required.
Aftermarket 3-point hitches can provide downforce, provided double-acting cylinders are used, and provided the right hyrdraulic controls are provided. This is actually an advantage over many early tractors that originally came with 3-point hitches.
If you do go with a 3-point hitch with double-acting cylinders, be VERY careful with the downforce. You could lift the rear of the tractor, making things VERY unstable. Safety first!!
Post A Followup
: Re: Re: Original Lift-all hitch Farmall H
