Re: Diesel fuel leaking from head gasket
Posted by JD Humm on April 18, 2002 at 14:42:14 from (67.202.50.174):
In Reply to: Diesel fuel leaking from head gasket posted by Peter Kosloski on April 18, 2002 at 13:11:00:
My 504 Diesel is 2/3 of the 656/560 engine. I had diesel fuel leaking from the front of the engine from the head gasket area, the tractor seemed to be running fine and I was loosing no oil or coolant either but it DID suck the front cylinder sleeve into the crankcase one day, it was the front cylinder that was also leaking. Do not know if the two incidents were related but that may be what is about to happen to your engine. The top breaks off the sleeve and the piston pulls it into the crankcase, this is a common problem with those engines. After the overhaul the leak was gone. Good luck.
Post A Followup
: Re: Re: Diesel fuel leaking from head gasket
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
