Farmall Tractors Discussion Board
Re: Removing stering gears
Posted by Skip on August 07, 1999 at 20:17:36 from (204.189.92.27):
In Reply to: Removing stering gears posted by John James on August 07, 1999 at 19:29:38:
You don't have to take the half moon gear off, just remove the plug from the front of case and screw the worm out the bearing will come also so be ready to catch it!!!!!
Good luck
Post a Followup
: Re: Re: Removing stering gears
