Farmall Tractors Discussion Board |
Re: Removing stering gears
Posted by R Rahmier on August 07, 1999 at 20:18:41 from (199.217.177.44):
In Reply to: Removing stering gears posted by John James on August 07, 1999 at 19:29:38:
with the nut off of the top the gear should pull strait off of the splineof the bolster shaft try taking a stiff wire and bend the end so you can stickit under the gear on either side and pull up on it
Post a Followup
