Re: Re: Re: Re: Re: Re: Re: Re: 3588 and 3788 same tracter
Posted by Hugh MacKay on April 23, 2002 at 11:01:55 from (209.226.106.55):
In Reply to: Re: Re: Re: Re: Re: Re: Re: 3588 and 3788 same tracter posted by RPM on April 23, 2002 at 08:04:22:
Had a hydraulic pump mounted with cushion type coupler to 1000 rpm shaft. Can't rememder capacity of pump but it did drive a Staffa 5 cylinder hydraulic motor that was capable of killing engine on 1066 turning 160hp. 3 items (1) width of drawbar cross bar was different. (2) distance from cross bar to pto was different. (3) distance from cross bar to top link pin was different. Could it be the fact that 1066 was cat III and 966 was cat II ? Would that make a difference? The bracket on torque tube was for resovoir and was measured by a third party. I will conceed on that. As for going to scrap yard I believe you and I have allready used enough time on this.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Re: 3588 and 3788 same tracter
