Re: Flaw with unfreezing stuck engine with hydraulics (Part II)
Posted by Craig MO on April 23, 2002 at 18:48:22 from (216.139.97.95):
In Reply to: Flaw with unfreezing stuck engine with hydraulics (Part II) posted by Dan Kelley on April 23, 2002 at 14:38:13:
I have heard a lot of silly ways to try and unstick motors but this is a good one. If you pump the cylinders full of grease it will just go out the valves because only one hloe will have both valves closed at any one time and then only on compression stroke close to top dead center. Why not take the head off pour penetrating oil in it and try to unstick using a bar. Before I would use a grease gun I would go to fence row and cut a hedge limb same size as bore get the maul and get rightous and start beating.
Post A Followup
: Re: Re: Flaw with unfreezing stuck engine with hydraulics (Part II)
