Farmall Tractors Discussion Board
Re: Re: Farmall A Cooling
Posted by The Red with followup on August 08, 1999 at 12:30:47 from (12.75.221.58):
In Reply to: Re: Farmall A Cooling posted by The Red on August 08, 1999 at 12:24:23:
Ray, sorry you did post both places. I just saw your post here.
I just looked in an old IT shop manual I have and you should have 50-60 psi with near full throttle, which is similar to the H. Anything below about 10 psi and you are not getting enough oil circulation.
Either the collection screen on the bottom of the oil pump is leaking or you have a leak in the pump. If its like the H, there are two halves to the pump housing with a gasket. You may be leaking there.
In any event, you are doing damage at that low of PSI unless your gauge is faulty.
Post a Followup
: Re: Re: Re: Farmall A Cooling
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
