Re: Sqeeling belt and fan wont turn I need help
Posted by Haas on April 27, 2002 at 16:40:16 from (63.234.87.48):
In Reply to: Sqeeling belt and fan wont turn I need help posted by Scott A on April 27, 2002 at 05:23:26:
The fan bearing has locked up, likely due to lack of oil in the hub. As others said, the oil in the hub needs to be checked on occassion to make sure it is has oil and is a proper level. You will have to remove the fan assembly and take it apart to find the problem. You will have to remove the hood and grill to get to it and you may have to remove the radiator, but I think you can get the fan and hub off without removing the radiator, but likely you will have to remove the shroud.
Post A Followup
: Re: Re: Sqeeling belt and fan wont turn I need help
