Farmall Tractors Discussion Board
I - H 300 Utility
Posted by Rocky on August 08, 1999 at 21:39:36 from (208.155.245.58):
The problem is the tractor will not move!! The engine runs as normal,PTO works fine, The trans shifts with or with out the clutch being depressed(no grinding) It looks like a real mess to remove the trans case cover. Any sugestions????? E mail would be welcomed.
Rocky
Post a Followup
: Re: I - H 300 Utility
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
