Farmall Tractors Discussion Board |
Re: I - H 300 Utility
Posted by john d. on August 09, 1999 at 10:38:22 from (206.141.74.34):
In Reply to: I - H 300 Utility posted by Rocky on August 08, 1999 at 21:39:36:
Some things to check before disassembly: Will the tractor roll if pushed? If not, brakes might be stuck. Did it run okay when last parked? If so, clutch may be stuck in released position. Shifts gears fine without grinding? Clutch must be releasing. Might not be engaging. Does engine labor when clutch is released in gear? If so, the brakes are suspect, or something jammed in transmission/rear end. If not, the clutch isn't engaging. Keep checking- and lots of luck!
Post a Followup
