Farmall Tractors Discussion Board
Re: Farmall B ??
Posted by big fred on August 09, 1999 at 07:58:33 from (12.13.226.15):
In Reply to: Farmall B ?? posted by Bill on August 09, 1999 at 07:36:46:
The rear tread on the B can be adjusted quite a bit, so 7 feet is easily accomplished. Think there are 16 possible positions adjusted 4 inches at a time. The left hand axle housing is the same as the right hand axle housing, so it will have seat mounting holes. Mine has a toolbox mounted to the outer holes. The dome on the manifold (exhaust part of the manifold) is for a pneumatic lift which works by diverting exhaust gases into a pneumatic cylinder. Since it is in the exhaust system, corrosion is a big problem, and I have seen a lot more of them not working that working.
Post a Followup
: Re: Re: Farmall B ??
