Re: Farmall M and C problems-kinda extensive
Posted by Bob M on April 30, 2002 at 17:01:47 from (66.66.72.246):
In Reply to: Farmall M and C problems-kinda extensive posted by Ken Christopherson on April 30, 2002 at 15:36:10:
To question #1: The leak would be from a bad seal on the pivot shaft. But if the gearbox is in good shape otherwise, simply mop out the remaining gear oil then fill the box with good grease. Grease will lube the steering gear fine but will not run out the seal like gear oil.
To #2: Time for a carb rebuild! Could have dirt in the needle valve, or a badly adjusted or broken (sunk) float. Don't be afraid to tackle the job yourself. These carbs are simple and gasket sets are cheap.
To #3: If the wiring is suspect (old, frayed insulation, etc), first replace the wiring harness. If the problem persists, then investigate starter switch, starter brushes, etc.
Good luck!
Post A Followup
: Re: Re: Farmall M and C problems-kinda extensive
