Re: Strange Fan Belt behavior on 1940 H - any ideas?
Posted by The Undertaker on May 02, 2002 at 08:10:02 from (64.40.66.140):
In Reply to: Strange Fan Belt behavior on 1940 H - any ideas? posted by Pete in PA on May 02, 2002 at 07:46:12:
Pete!
Could it be the set screw in the fan pulley adjustable flange is loose, or maybe belt has worn enough that the flange needs moved up a little. Maybe it is loose enough that when belt is cool and contracts it turns the pulley, but when warm it stretches out and slips?
"TU"
Post A Followup
: Re: Re: Strange Fan Belt behavior on 1940 H - any ideas?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
