Farmall Tractors Discussion Board
Re: 350 utility T/A Won't go in Low
Posted by RickB. on August 09, 1999 at 18:26:45 from (205.231.28.114):
In Reply to: 350 utility T/A Won't go in Low posted by Wayne on August 09, 1999 at 17:10:03:
By most folk's standards, a TA rebuild is a big deal. The center section of the tractor has to come out (double split) to access the ramp & carrier, which is the failed assembly when low doesn't work. a $500 bill plus some more for gaskets & seals will be the bare minimum in parts only. I did the TA in my 400, replacing the TA clutch & pressure plate, main clutch ,release & pilot bearings, and rear main seal "while I was in there" and spoiled $1000 in parts. Using just direct drive will do no further damage to your 350.
Post a Followup
: Re: Re: 350 utility T/A Won't go in Low
