F-12 Valve Cover bolt
Posted by Stevie on May 04, 2002 at 09:40:57 from (198.81.16.167):
Hello. I have an F-12 with the three studs that hold the valve cover on. I would like to know if there is a special nut that holds the valve cover on or can I just put any one on that will fit. Trying to get it as close to orignal as possible. Thanks in advance.
Post A Followup
: Re: F-12 Valve Cover bolt
