Re: Steering Wheel, Seat Bushings, etc.
Posted by gene b on May 05, 2002 at 00:33:13 from (63.186.33.84):
In Reply to: Steering Wheel, Seat Bushings, etc. posted by Wanna B on May 04, 2002 at 17:42:05:
the original seat does not have bushings or a shock you have an aftermarket seat you can get new steeringwheels for 65.00 and a rad cap for 6.00 carb must not be in too bad shape or it wouldnt run at all next time it stops check for spark sounds like the condenser or the coil is not trouble with fuel or it wouldnt run at all if the gas line is plugged wont run over a minute or so you can also check when it stops take plug out of bottom of carb and if gas is there its not a fuel problem then check spark you eithewr dont have one of the other
Post A Followup
: Re: Re: Steering Wheel, Seat Bushings, etc.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
