Re: Re: 43 H won't charge
Posted by Bob M on May 05, 2002 at 08:52:36 from (66.66.72.246):
In Reply to: Re: 43 H won't charge posted by L.C. Draper on May 05, 2002 at 08:14:20:
LC - The original wiring diagram shows no connection to the "F" terminal on the cutout (no idea why the terminal was provided in the first place.) And the electronic cutout you have now is indeed a sealed unit - only thing inside is a solid state diode.
Have you polarized the generator? (With the motor stopped use a jumper wire to momentarily connect the generator "A" or "ARM" terminal to the cutout "BAT" terminal). If that doesn't do it, I'd then suspect a problem with the generator itself.
...Bob M
Post A Followup
: Re: Re: Re: 43 H won't charge
