Re: IH 350 Utility Hydraulic questions
Posted by Harold Hubbard on May 06, 2002 at 04:55:23 from (216.114.163.51):
In Reply to: IH 350 Utility Hydraulic questions posted by Bob Stratton on May 05, 2002 at 20:51:37:
Are you sure the problem is in the hydraulics? On my 330U, which is very similar, there is a pin in the bottome of the cylinder that can be removed and replaced, depending on whether you want the hitch to float. If the pin is not in place, there is no down pressure. With the tractor shut off and no implement on the hitch, if you can raise the hitch by hand or with a bar, the pin is not installed. Also, under power, see if the cylinder extends when you try to put the hitch down, even if the hitch itself doesn't actually move. As far as the speed of operation, I think it may be just naturally slow, my 330 is. Again, if the pin isn't in place, the cylinder will extend all the way when you lower an implement, and must come back partway before it starts raising the hitch. Watch the hitch and cylinder to see if this is what's happening.
Post A Followup
: Re: Re: IH 350 Utility Hydraulic questions
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
