Farmall Tractors Discussion Board
Re: IGNITION MADNESS
Posted by Regularman on August 10, 1999 at 09:47:57 from (147.160.180.17):
In Reply to: IGNITION MADNESS posted by Tim B on August 09, 1999 at 17:04:12:
It sounds to me like you managed to get you rotor out of time inside your mag. When you replaced the points did you remove the small cap that covers the gears that run the rotor? If so that needs to be correctly timed first. Also, when this gear housing is reinstalled over the points it has a flat spot on the shaft to keep it in time. If the shaft is worn you may have forced it together and it's not properly lined up. Hope this helps.
Post a Followup
: Re: Re: IGNITION MADNESS
