Farmall A Manifold Studs
Posted by tom on May 07, 2002 at 17:38:13 from (206.243.130.72):
Good day,
I removed my Farmall A manifold today and the last person who installed it used the standard steel nuts on two of the studs rather than the brass nuts.
To make a long story short, the steel nuts seemd to have crosss threaded two studs and I'm thinking about replacing them. Being a novice to studs on tractors, what is the best way to remove them? Just clamp down on them with vise grips and remove them...or is there another and better approach to removing and installing manifold studs?
p.s I suppose, once they are removed I can take them to a NAPA and have them matched? or, are they unique to the Farmall A types with a special size?
thanks. tom
Post A Followup
: Re: Farmall A Manifold Studs
