Re: H won't run w/o choke
Posted by Night Stalker on May 08, 2002 at 20:21:43 from (207.239.97.193):
In Reply to: H won't run w/o choke posted by David Ross on May 08, 2002 at 20:03:40:
I don't know if this would apply to your needing to use the choke to run, But You may want to check for an Air Leak somewhere.
I rebuilt a carb on one of my H's only to find that it was not getting a good seal between the carb and manifold. I also had to use the choke to get it to run. Checked for air leaks and found the gasket was not sealing, replaced the gasket and it ran fine afterwards.
Hope it is this simple for you.
Good Luck
Night Stalker
Post A Followup
: Re: Re: H won't run w/o choke
