Re: 1206,1256 camshaft the same?
Posted by RPM on May 09, 2002 at 06:37:28 from (63.110.182.225):
In Reply to: 1206,1256 camshaft the same? posted by Red Reaper on May 08, 2002 at 19:14:21:
The cam is the same from 806 through 1456, D361/DT361, D407/DT407, We had to replace a lot of these over the years when these series were the tractors of choice in the 60s & 70s, they had a problem with the front crank dampener pulley failing from age, the rubber would come apart, it would break off the camshaft right behind the cam gear. It would also break gear teeth on crank gear or pump drive gear, bend pushrods, break rocker arms, bend valves when this happened. If you are replacing with used parts be very critical of the crank damper pulley, if any rubber is coming out or chunking/cracking I would advise you to get a new one or a visually good used one. The cam part now is 670349C1, you will also need to add flange 16027DB to make it fit.
Post A Followup
: Re: Re: 1206,1256 camshaft the same?
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
