Farmall h carb. and manifold
Posted by Bob on May 09, 2002 at 10:09:41 from (166.102.96.84):
On my 42 h I was wondering what the torque spec for the manifold is. Also should I use high temp. sealant on the gaskets, seems to be leaky without it. Also should I put sealant on the gasket that goes between the two halves of the carb? It is leaking gas through it a little bit. Also should I put sealant on the gasket that goes between the carb and manifold? Thanks! Bob
Post A Followup
: Re: Farmall h carb. and manifold
