Re: Farmall h carb. and manifold
Posted by Theman on May 09, 2002 at 11:32:02 from (12.19.86.5):
In Reply to: Farmall h carb. and manifold posted by Bob on May 09, 2002 at 10:09:41:
Bob, manifold torque depends on whether you are tightening fine threaded nuts on the original studs...or going with the IH approved replacement method of using 7/16" coarse grade 8 bolts. I put my after-market manifold on with the second method using plenty of copper based anti-seize. I personally don't put sealer on any manifold gaskets. If they are leaking, I always get new ones. Sealer, in my experience, has provided a way for heat and exhaust pressure to create more leaks than they prevent. I do not recommend using sealer on the bowl gasket of the carb because you can very easily plug up the idle passage. I took a picture of the RTV silicone plug that came out of the carb of my H. There's no way it could have run right before it was parked. In fact, that may be the very reason it was sitting along the fence. The gasket between the carb and manifold is under light vacuum. If both surfaces are clean and flat, there should be no leakage with moderate tension on the studs/bolts. Again, I don't use sealer at this joint. It also makes removal much easier at a later time.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
