farmall h popping
Posted by bob on May 09, 2002 at 17:57:52 from (162.39.8.116):
I just recently rebuilt motor and carb. on my H and when it is running it has a slight popping sound from the exhaust. I thought carb. needed adjusted but when I turn the needles they don't make a difference. Also when you let out clutch motor boggs a little bit then picks back up also does this if using brakes to turn. This happens at any RPM. I was thinking maybe sucking air around manifold? Could this cause this? Thanks!
Post A Followup
: Re: farmall h popping
