Re: Re: IH 140 hydraulic problems
Posted by ddg on May 09, 2002 at 20:06:01 from (152.163.201.57):
In Reply to: Re: IH 140 hydraulic problems posted by Hugh MacKay on May 09, 2002 at 16:42:24:
My Super A stuck in the high pressure position, and got the fluid hot. In the lower right part of the head, there is a plug. (I had to take the battery box out to get to it) Take the plug out, and you'll see a slotted screw & orfice. Unscrew it, and pull it out, there should be a cone shapped strainer on it. Mine had a hole in it, and a piece of grit about the size of a grain of sand had plugged the orfice. It worked normally when I removed that piece of grit.
Post A Followup
: Re: Re: Re: IH 140 hydraulic problems
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
