Re: IH 140 hydraulic problems
Posted by Hugh MacKay on May 09, 2002 at 16:42:24 from (209.226.247.54):
In Reply to: IH 140 hydraulic problems posted by David on May 09, 2002 at 10:56:06:
Sometimes the frame work that goes around your hydraulic levers can get moved a bit and cause pump to labour as lever is going farther than designed for, but it will only do it at one end, so it is not hard to diagnose or fix. There has to be a relief valve but my 130 relief valve hasn't been a problem in 45 years. Have had the other happen several times.
Post A Followup
: Re: Re: IH 140 hydraulic problems
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
