Re: pulling 706 in gear, other ??
Posted by Ace Schrunk on May 10, 2002 at 10:31:14 from (209.180.99.130):
In Reply to: pulling 706 in gear, other ?? posted by Ih Puller on May 10, 2002 at 09:52:50:
TA clutch is hydraulic that is what the lever on left side is for forward is high back is low and no you should not pull it unless range transmission is in neutral. about 72 hp
Post A Followup
: Re: Re: pulling 706 in gear, other ??
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
