Re: No Load Miss on M, please help...Runs great with a load.
Posted by gene b on May 13, 2002 at 02:07:49 from (63.25.166.228):
In Reply to: No Load Miss on M, please help...Runs great with a load. posted by Mr. J on May 12, 2002 at 22:48:58:
you are in time as the mag fires on top dead center take out #1 plug turn over on compression get piston at top then see as the rotor will be lined up with the #1 POST ON THE CAP YOU CANNOT ADVANCE THE MAG it fires on tdc then goes to 34deg when engine is running
Post A Followup
: Re: Re: No Load Miss on M, please help...Runs great with a load.
