H cARBURETOR
Posted by mel on May 14, 2002 at 04:05:28 from (198.26.123.37):
I finished putting the carb back together last night and then I put it on the H. The tractor fired right up. I adjusted the carb by turning the idle screw in until the engine started to die and then turned it out one turn. Did this both at low rpms and high. It seems to run fine now. Is that the right procedure to adjust the carb??? If anyone needs the carb repair kit number it was 354452R92 My carb was the 45108 on the H.
Post A Followup
: Re: H cARBURETOR
