Re: farmall a only get high revs
Posted by EZ on May 14, 2002 at 19:22:27 from (216.211.7.172):
In Reply to: farmall a only get high revs posted by tiny on May 14, 2002 at 17:01:48:
Tiny, I had the same problem as you have and for sure the way to cure it is to adjust that clevis pin on the governor arm. You might be able to figure how much you have to adjust it by watching how much you have to move the arm maually to stop the high revs. I had to adjust a couple times til I got it. Good Luck.
Post A Followup
: Re: Re: farmall a only get high revs
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
