Re: 450 power steering, HELP!
Posted by kal on May 16, 2002 at 15:11:03 from (63.11.140.206):
In Reply to: 450 power steering, HELP! posted by J.D. on May 16, 2002 at 12:57:08:
In between two of the auxilary valves is a plug with an oring on it.The edge of the plug could be broken off or the oring bad.This will cause your steering symtoms.Be very carefull when you start the tractor after working on the steering motor ,it might take off on way or the other.Don't remember which valves plug is between.
Post A Followup
: Re: Re: 450 power steering, HELP!
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
