Need tips on M governor
Posted by Jeff - Ohio on May 16, 2002 at 16:33:30 from (152.163.213.48):
Picked up a governor assembly for my M on the auction and want to overhaul it. I've got the gear off the front of the shaft and snap ring off the front bearing but need advice on removing the bearing. Also, I've got in mind what I need to pick up for the rebuild (front and back bearing, rockshaft needle bearings, etc) but would appreciate knowing for sure what i'll need. I know the fellas at the Case/IH dealer could help me but you all seem to be on top of it too.
Post A Followup
: Re: Need tips on M governor
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
