Re: Need tips on M governor
Posted by Theman on May 17, 2002 at 06:10:10 from (12.19.86.5):
In Reply to: Need tips on M governor posted by Jeff - Ohio on May 16, 2002 at 16:33:30:
Jeff, if the M governor is anything like the H, remove the control shaft first. There is a woodruff (half moon) key in the stop arm that the spring hooks to so it has to come straight off. Once the control shaft is out the main shaft can be pulled out. This is a good place to use a slide hammer type wheel puller. You will find, as I did, that the snap ring doesn't need to be removed at all. It is on the bearing to take the thrust developed from the helical cut drive gear. The bearing comes out of the housing with the shaft. Once the shaft and bearing assembly is out, you can drive the shaft back out of the bearing either by placing it over the jaws of your vise or in an arbor press. The pivot shaft goes into a blind hole and has to be pulled out of the cover side of the housing. If there is rust on the shaft between the needle bearings it can be tough to get out. Something else to check while you have it apart is the condition of the pins in the yoke that contact the outer race of the thrust bearing. If they are badly worn they should be replaced or at the very least, pressed out and turned so you don't run out of adjustment on the vertical rod that the throttle shaft connects to. If left with too much space, you'll have trouble getting the engine to come to a slow idle. The alternative to fooling with worn pins is to add a spacer the thickeness of the pin wear between the thrust bearing and the sliding collar that the weights move. Reading this, it sounds more complicated than it really is. It will make more sense when you get everything apart.
Home
| Forums
Today's Featured Article -
The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
