Bull pinion/brake shaft
Posted by Obie nh on May 17, 2002 at 02:28:04 from (152.163.205.69):
I knew I needed some brake work on my 39 H and tore the brakes out to find out they were trash.I also had lots of gear oil which must be the oil seal.The shafts both had a bit of play from side to side ,think the 2 bearings need to be replaced also.Is that a big job to replace the bearings on the brake shaft,and any tips on how to do it?I took the cast housing bolts off but cant get the housing to come out? Any help will be great.Thanks Obie
Post A Followup
: Re: Bull pinion/brake shaft
