H draw bar extension (Again)
Posted by Richard C on May 17, 2002 at 12:25:23 from (208.31.27.251):
Another question about the extension on the drawbar.....
If the correct distance from the shaft to the hitch is 14inched then if I put on a over-run clutch in theory I would need an extension on my extension right? Just an after thought. I will let yall know what works whenever I get the parts together..
Richard
Post A Followup
: Re: H draw bar extension (Again)
