Re: H draw bar extension (Again)
Posted by Andy Martin on May 17, 2002 at 15:25:57 from (12.74.160.98):
In Reply to: H draw bar extension (Again) posted by Richard C on May 17, 2002 at 12:25:23:
Yes you are right. For the driveline to work properly without chattering on sharp turns you need to abide by the ASAE standards for distance from the PTO to hitch pin and also the elevation from the PTO to the drawbar.
It will work without an added extension but you'll find you have to limit your turns more.
Post A Followup
: Re: Re: H draw bar extension (Again)
