Re: Farmall 560 LP Gas backfires
Posted by scott AR on May 23, 2002 at 19:38:44 from (209.194.159.169):
In Reply to: Farmall 560 LP Gas backfires posted by Ron McClendon on May 23, 2002 at 13:55:24:
I guess there are several things that could cause the backfire but I would check in this order. Double check the firing order and your spark plug wires and if you are sure it is firing at the right time, I would take off the valve cover and see if there is a loose rocker arm caused by a stuck valve. I have had good luck with stuck valves by making a liberal application of lubricant on the stem and pecking it down with a SMALL hammer and prying up with two pry bars until it cooperates. If it is firing with the valve open, it is burning in the intake instead of the engine.
Post A Followup
: Re: Re: Farmall 560 LP Gas backfires
