the orfice was marked 31 and it has a screen on the end of it. it has never had a check ball installed in the orfice port. should i remove the screen to allow more flow? every time i've had it apart i have cleaned it and made sure i could see through the orfice. When i first pulled the orfice out (due to org pump going out) the screen was smashed in on itsself. i desoldered it cleaned it and resolded it back on and made it just like new..(new one was over $50.00)
when i first fired it up it had very good responce from the system to the control levers. when it was making whining sound it was also making a pulsating sound and the 3/4in hose that goes from the pump to the hydra-touch system would pulsate with the pump after it warmed up from working ground and i had no responce. just went back to the field and fired it up and i was able to lift the cultivator.
The tractor has around 1300 hours on a working tach, did you see the wear on the tele-a-depth system around these hours? i could not find much slop/play in the linkages.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
