Re: 560 killed new hydrualic pump HELP
Posted by pete 23 on March 26, 2009 at 18:41:21 from (173.87.1.12):
In Reply to: 560 killed new hydrualic pump HELP posted by ITFormulaGuY on March 26, 2009 at 17:14:02:
The pump may or may not be toast now, can't say. When you get her running you have to establish that it does not stay on demand and it is most likely to do that after it has completely warmed up. Did the .031 orfice actually have a hole that size. If it has or had a check ball in them they will pean that hole shut and the seat is hardened so very difficult to drill out. The ones that had check balls had a cross drilled hole for a roll pin to hold the ball in. Provided you have no other reason for system staying on demand, like bent or missing roll pins where you switch from single to double action, the problem is unduoubtly caused by wear in the hitch teledepth valve land that controls the passage to the orfice. What I have done over the years is to progressively drill the orfice size out until I get a system that quickly responds to lever movement but does not stay on demand. Neutral regulated pressure should run about 30 to 60 psi, not over 100psi. You need to install a gauge right at the pump and observe it as tractor is being worked in the field until you reach these conditions unless you feel your able to readily determine it by ear. They will get so hot you can fry an egg on the housing and of course ruin all 0-rings , seals through out .
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
