Re: FAA No start checklist
Posted by Gene on May 30, 2002 at 08:39:07 from (65.56.58.217):
In Reply to: FAA No start checklist posted by Joseph P on May 30, 2002 at 05:05:31:
Joeseph: Soft copper wire inside front cylinder to tell when piston nears top is only HALF correct. You need to hold plug hole shut with finger to feel COMPRESSION when piston is coming up other wise you may be coming up on the EXHAUST stroke. There are TWO times the piston comes up. Only one,on compression, is when the plug fires. Small detail but easy to overlook. You'll get there. Pulling the other three plugs makes it easier to crank by hand. G.
Post A Followup
: Re: Re: FAA No start checklist
