FAA No start checklist
Posted by Joseph P on May 30, 2002 at 05:05:31 from (206.243.130.20):
Battery charged - full. Plug wires to dist cap in correct order. Timing: appears to be correct TDC #1 rotor to 1 (I used a small copper wire, and inserted into plug chamber, and rotated fan as wire slippedupward thorough finger and maxed out, observed position of rotor and was in line with #1 on distributor cap.) Assuming that this is compression stroke because I did not remove the megneto or attempt to turn over engine during painting touch up...timing should not have changed). Magneto appears to be sending "some" current due to light test meter on side shutdown post. But weak light response. Barely flickers as points open and close. Motor turns over. Starter engages. 6V with regulator (4 contacts/connections). No spark at plugs. Gas to plugs. Seems that plugs are a little wet and smell like gasoline. Waiting on tune-up kit to arrive. Will work on cleaning, tightening the inside of magneto later today and install new points and condensor too. Setting gap to .13. Will give that a try before I post results. If I am missing somehting, or if you think of something I am overlooking let me know. You'all have helped me narrow down the location of the problem (I hope) and helped me better understand magneto system and FAA ignition system. I'm on a steep learning curve, and I need your help to get me there. TYIA. Joseph P
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
