generator not charging, or battery losing charge
Posted by tom on June 02, 2002 at 04:50:17 from (206.243.130.236):
problem area to understand and learn:
6V generator. 41 A. Regulator on generator..
New wires, all in correct placement according to diagrams. Good contacts.
Remove ground cable everytime I shut tractor down.
Ammeter works. With lights on shows negative discharge.
Upon start-up, and during running, ammeter shows 0. No movement.
Battery rins down and not charging.
Need some education regulators, and, generators. Can get it tested easy enough, but windering if there is something I can do here in the shed to determine cause. I have no voltmeter.
Also, what are the advantages to the regulator v.s. cutout? and or vice versa, what does a cutout do that a regulator does or doesn't do?
Need some basics in the charging system.
thanks. tom
Post A Followup
: Re: generator not charging, or battery losing charge
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
