Re: generator not charging, or battery losing charge
Posted by Haas on June 02, 2002 at 15:08:00 from (166.72.245.211):
In Reply to: generator not charging, or battery losing charge posted by tom on June 02, 2002 at 04:50:17:
Sounds like your generator is not charging, or you have a problem with the regulator. As others said, try polarizing the generator. If that does not work, make sure your regulator has a good ground. Paint under the mounting lugs of the regulator can be enough resistance to keep the regulator from working and charging the batter. Put a wire under the generator mounting lug and connect it to the battery ground and see it it starts charging. Also to check if the generator is working, connect a wire to the field (F) terminal and with the tractor running ground that to the battery ground. If the generator is working, it should show charge. If the regulator is properly grounded and you only get charge when you ground the field terminal of the generator, then the regulator is bad. Make sure to NOT ground the ARM or GEN terminal of the generator. You can ruin the generator.
Post A Followup
: Re: Re: generator not charging, or battery losing charge
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
