Re: Gas Line: There must be a trick
Posted by Fred on June 03, 2002 at 12:33:36 from (24.151.42.83):
In Reply to: Gas Line: There must be a trick posted by JackNY on June 03, 2002 at 11:21:12:
they commonly had a ferel on either end, and you should have enough room to cut the bad end off(nut and ferrel) the tank end,replace the nut and ferrel from your local napa store. That is really the only reason they leak,make sure you did not strip the bowl under the tank or the carb inlet as it is fairly easy to damage them,good luck!
Post A Followup
: Re: Re: Gas Line: There must be a trick
