Re: H leak
Posted by BIG JOHN on June 03, 2002 at 18:09:18 from (64.12.105.174):
In Reply to: H leak posted by martin mueller on June 03, 2002 at 14:57:58:
Gray, usually means you have water in your gear case. If your H has been out in the rain it is almost certain that you will have water in the case. Open the full level plug. If you have water and it has caused it to be over full it could have pushed the fluid out of the front seal.
After your tractor has set for a day to two the water will seperate from the oil and will go to the bottom. When you open the drain plug you will get pure water first and then the gear lube.
If you find water I would change the gear lub and monitor the level very close. You may find that will take care of it without any major repairs. If you can't keep your tractor under cover then you should put a tarp over the transmission/rear end to keep the water out.
GOOD LUCK
Post A Followup
: Re: Re: H leak
