Re: Super C Idling problem
Posted by Farmer Bob on June 03, 2002 at 20:53:18 from (66.152.73.65):
In Reply to: Super C Idling problem posted by Farmall ED on June 03, 2002 at 18:54:23:
Ed, Did you check to see if the idle adjustment on the carb butterfly is not set to high? Its a screw adjustment on the back (Engine) side of the carb where the governor control rod attaches. you may be able to unscrew it some to get it to idle down. Also check the yoke on the control rod and set it per the manual. Post back if this doesn't fix the problem. (Or if it does).//FB
Post A Followup
: Re: Re: Super C Idling problem
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
