Re: 806; engine needs overhaul; questions,(long post)
Posted by Pat H on June 03, 2002 at 23:18:35 from (66.187.38.34):
In Reply to: 806; engine needs overhaul; questions,(long post) posted by Curt; from East Central WI on June 03, 2002 at 21:09:19:
got a m&w turbo on the wifes 806 ,didn't have to change manifold.kept injection pump set the same smokes less and can run straight pipe on it cause turbo seems to quiet it some.temp gauge went bad and I smeared a piston {didnt know it was running hot}.if you turbo it make sure your gauges work cause you"ll be able to run a gear higher without lugging out but you need to keep it cool.now with new gauges this tractor really impresses me, good power and still easy on diesel fuel
Post A Followup
: Re: Re: 806; engine needs overhaul; questions,(long post)
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
