Re: Re: Hyd Pump drive link--can't remove from H
Posted by Dick Davis on June 04, 2002 at 04:11:24 from (205.188.200.138):
In Reply to: Re: Hyd Pump drive link--can't remove from H posted by williamf on June 04, 2002 at 03:18:33:
I also am do for an H belly pump hydraulic seal repair. Obviously I should have replaced the seals last time the pump was out! How difficult is the seal change once the pump is on the ground? I'd guess you change both ends at the same time? Anybody got the seal part numbers handy? Thanks Dick
Post A Followup
: Re: Re: Re: Hyd Pump drive link--can't remove from H
