Re: H/460 wf compatablility
Posted by RPM on June 04, 2002 at 06:12:39 from (63.110.182.225):
In Reply to: H/460 wf compatablility posted by Bleedinred on June 03, 2002 at 22:36:59:
It will probably bolt on ok, hub & bearings will be a problem, if threads on spindle are coarse threads, then its most likely H, bearings alone will not adapt it to 460 spindle bearings, 460 has 3/4 fine threads. The hub spacing for bearing seats are different, would require new spindles to get it to match up correctly. New spindles are $150.
Post A Followup
: Re: Re: H/460 wf compatablility
